Help! High Beam DRL Conversion? How?
Discussion in 'Exterior' started by Yinster, Mar 19, 2014.
    Yinster Well-Known Member
    Hawaii
    Hey gentlemen, so i have a 01 corolla, currently have a switch for DRL already. But i would love to convert my DRL Beam from low to high ( like the one on camry), anyone know how to do it , thanks
    Don't take my word for it, but I think all you have to do is wire it into the harness that is underneath the glovebox, the same one you cut to disable them. You say you have it wired to a switch so I'm thinking that it would all be connected somehow.
    Hawaii
    yeah i was thinking it might be as simple as it is swapping wire, but i just have no clue as of now
    Or what you could try is just keep the wiring exactly the same, but swap the bulbs around. Put your low beams into the high beam spot, and put the high beam bulbs into the low beam socket. Then when the DRLs come on it'll be in the high beam area. Just a thought, but then your regular headlights will be reversed for nighttime driving, which could be confusing.
    Hawaii
    well, that could work, but isnt the high and low will be opposite lol
    Yeah that's what I was saying lol
    :dafuq:
    :corner:
    lol
    Hawaii
    yeah, still cant find a real solution lol
    i know some 9th gen owner did a swap DRL on theirs, do you think it will work on 8.5 gen too?
    If anyone still got ideas?
    Hawaii
    Hawaii
    Not sure if that would work on an 8th gen Corolla, though I don't know one way or the other.
    Hmmm it would probably work but I can't say for sure, since I completely disabled everything.
    Hawaii
    well , i disconnect my DRL and wire it to a switch. Maybe over the summer i will try it and report to you guys. It isnt gonna work for 8th gen for sure (cause 8th gen use single bulb for High and low,right?) but 8.5 (01-02) got high and low separated .
    Yeah the 98-00 won't work like that for sure but you don't have to worry about that lol
    Hawaii
    alright man, thanks for all the tips, if anyone still got any, please share em lol
    Sad to say it but TN is better for the technical stuff like that. They have hundreds if not thousands of active members, we have like 8. Lol
    but most are 1 time posters trying to find out why the corolla is consuming oil or adding led to the car -_-
    I'm referring to the entire forum, not just the tiny 8th gen section lol
    Hawaii
    yeah thats true i guess, but most of the time the post isnt really helpful lol
    That's why it's more fun here!
    :awyeah::awyeah::awyeah::awyeah:
    Hawaii
    :idosay: damn right
    :truestory:
