HID problems. help
Discussion in 'Exterior' started by justdoitmikey, Nov 22, 2005.
    justdoitmikey Guest
    HID problems. help
    Ok I have a 99 with HID's. My RH light fails to light after like 4 mths of use. It did it once a few days ago, I turned it off then back on and it caught, it lit slowly to full but it did reach the full color. Today it took like 5 times, turning it off wait ten try it again, before it turned on. Is there an easy way to figure out what went bad? Also my other kit on the same side went bad is there anyway that the car is doing something to cause it to fail early? Any clues? Help!! Also what fuses am I supposed to replace, there are 4 labled headlights.
    ghoztrider New Member
    Suburb of Philadelphia, PA
    if u have warranty just return it, i got life time warranty on my HID kit
    laz Member
    NYC
    bad ballast, hopefully you have warranty on them.
    X
