HID problem?
Discussion in 'Care & Maintenance' started by JordanInc, Jan 3, 2008.
    JordanInc ZZE110
    HID problem?
    i installed my HIDs recently, and its weird
    sometimes when is start off my car at night, the HIDs wont turn on, all you see is the signal lights on, the HIDs arent
    then sometimes i would turn off the car, and start it up again to see if the lights turn on, and if im lucky it will, but then in another case one of them will start blinking like its on steroids, and eventually work...orrrrrrrrrr in the worst case, it still wont turn on and i have to turn my car off and on til it works
    is this normal??? or is it cuz i got some cheap ass HIDs
    my friend told me cuz its new and it needs to break in, but i dont know
    my other friend told me cuz its a shitty cheap brand i bought
    you burn it in when you first install it..
    its probably a shitty brand but i bought a shitty brand for my low beams and it hasnt failed me yet. maybe its your installation?
    Your ballasts/igniters are crappy. Don't forget to double check your connections and wiring.
    DOT. Noypi ako!
    Have it exchange while it's under warranty.
    zcorolla New Member
    did you disable the drl's? that could be it if you didnt. other than that, you probably touched the bulb during install or maybe some wrong wiring.
    You shoud've bought from a reputable company. There were a few group buys on ToyotaNation. The Mod-Express HID buy was a great deal.
    zcorolla New Member
    JordanInc ZZE110
    ya i just figured that's probably the reason.
    It's always mandatory to disable the DRLs when utilizing HIDs.
    JordanInc ZZE110
    krazykanuk New Member
    how do you disable the DRLs
    zcorolla New Member
    ugh...interesting questions.
    DjiNN New Member
    So the DRL affects the HID setup? thats weird .. i wouldve thought that it would work along with the HID setup .. so how would u turn on the lights if u disable the DRL>?
    Like how normal people do it, using the light switch... ROFL Don't tell me, you never turned on your lights before? Even if the DRLs come on automatically in the dark, cops will pull you over because your parking lights won't be on.
    HIDs don't use filaments so they can't run at a partial voltage.
    MattAveli Modifier
    Cold Ass Canada
    it's your drl's, there not giving the proper voltage to the ballast.
    If you don't want to disable the DRL. Then just turn on the headlight BEFORE you start the car and keep it on until you shut down the car.
    And turn it off AFTER you shut down the car.
    That works, but real ghetto. LOL :D
    ROFLMAO
    DOT. Noypi ako!
    Isn't it harder to install the HID than disabling the DLR?
    You can disable it anytime with or without HID's installed.
    jcrwzr Member
    Simi Valley, CA
    dude, thats the first thing i did. i went to vamp's page, cut pin 23 the red wire with the blue stripe, and proceeded with the hid install
    DLR is for losers. LOL JK I just never liked the idea. It's a waste of R&D to me.
    jcrwzr Member
    Simi Valley, CA
    drls are for those morons who get tickets for not turning on their lights between dusk and dawn
    DOT. Noypi ako!
    JordanInc ZZE110
    actually, i still havent disabled my DRLs yet,
    so ive been doing that switch headlights on before i turn on the car thing too, HAHA
