HID problem
Discussion in 'Exterior' started by Corolla DX-R, Nov 17, 2006.
    Corolla DX-R AE100
    Vancouver, B.C.
    i had no problem w/ mine... check your wiring could be some loose wiring...
    R1dg3xrac3r Guest
    HID problem
    Hey guys. I have a 00 corolla and I have HIDs installed. Whenever I am at a stop light. THe lights would flicker sometimes. Do any of you have the same problem ? Also where is a place that you guys mount your ballast ?
    R1dg3xrac3r Guest
    nah, all the connections are tight. My buddy says the ballast need to be mounted tight. I don't know where is a good place to mount the ballast on a 00 corolla....any suggestions ? Pictures would be nice
    Theres barely any room to mount the ballasts in a 98-02. I got a 98 and one is mounted where the wiper fluid resovoir used to be. The other one is zip tied to my grounding kit behind the headlight. btw, are ur ballasts shockproof? That could be the reason why. And what brand u got?
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I mounted my ballasted under the headlights on the bumper support.
