HID malfunction
Discussion in 'Exterior' started by ProjRola, Dec 20, 2005.
    ProjRola Guest
    HID malfunction
    I bought these HIDs and put them on the rolla and for some reason the electronic gear box blew. i had a second pair put in and the same thing happened. Does anyone know why this is happening?
    did you wire them properly? did you buy a set that's too strong for the car? what brand did you buy, and how did you install them? specifics will get you answers. :)
    ProjRola Guest
    Well from the looks of the kit, there is only 1 way to connect them. I bought 8000k, is that to powerful? I purchased PHILLIPS. I connected the ballast to an extension to connect it to the stock wiring harness. then connected the head-lights. specific enough?
    ghoztrider New Member
    Suburb of Philadelphia, PA
    no such thing as having a color temperature as too powerful, still takes the same wattage, its either the kit itself is bad or there is something wrong with ur fuses or ur wiring job
