Engine Hey Guys Pls Help 4agze Questions Here Thanks
Discussion in 'Powertrain' started by TRD_Rider, Dec 28, 2007.
    TRD_Rider Guest
    i need to know what tranny is on my 4agze (ae92) (MAP) .... i need to get new cv shafts and i dont know what to get ..will the ones from the 4agze mr2 fit???? or would some from the 3sgte mr2 do??? or maybe some from the 5sfe camry??? pls let me know asap
    and also i did not get my MAP sensor and i wanted to know if i could use the one from the 22RE.... or maybe one from an other toyota engine pls let me know....
    and also i am swaping this set up in a 95 corolla that used to have electronic speed sensor is there any way i can make the speedomiter work??? my old speed sensor is to small what other speed sensor can fit in my tranny???
    so if any of you have any info pls let me know thank you all very much ......
    t0rres16 Member
    Yardley, PA
    if the 22RE works then u should get a supra MAP sensor because a lot of 22RE guys use them and its a plug and play
    TRD_Rider Guest
    sweet thanks man that actually helps alot more than you could ever think cause some one told me that the supra one would work but not much others would .....so :D and i was planning on putting a supra on in in a wile lol its expensive when your just tring to finish a swap lol so i just need it to run for now lol but thanks very much
    t0rres16 Member
    Yardley, PA
    No problem hope everything works out and u can get ur car running
