HELP!
Discussion in 'Exterior' started by PilotGuy, Jun 23, 2003.
    PilotGuy Guest
    HELP!
    ok I was driving along in a neighborhood and I decide to turn around. So I pull into his driveway with no problems, then when I back up I hear this loud scraping noise. So I go and park my car thinking it was just like the metal pieces under my car, and Its not! its the underside of my drivers side undebody spoiler thing! What do I do? I know its made out of plastic so it wont rust, But i also noticed like a clip thing that attatches it to the car has disconnected, Should I take it to toyota? is this covered in the warranty? ( worth a shot!)\
    Help!!! :oops: :oops: :oops:
    03ToyMan New Member
    I'd guess banging your skirt wouldn't be covered under warrenty, but you could drop the line "well I can't afford to fix it, and you don't want me driving around looking bad, bad press for you, so...".
    worth a shot...
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    actually that guy klepto had the same problem with his skirt falling off. Toyota wont fix it so he just got some clips and screws and sort of attached it permanent. that is the best option that you have to avoid loosing it or doing further damage if i understand right.
    PilotGuy Guest
    What If I went to Toyota and asked THEM to bolt it back on?
    stinky Guest
    Im sure they have no problem doing what you ask them to do. But I bet they have no problem "asking you" for $20 per clip used, and $75 an hour for their lube guy to clip it on.
    Jersey City, NJ
    just buy some clips, fresh 3m tape and go to work on it. it will be back to new and last longer too
    PilotGuy Guest
    I called them, they said that this is very common and they said its $39.99 to reattatch.
    Jersey City, NJ
    so let me get this straight, its very common so instead of fixing it, they will charge you 40 bux. just do it yourself man, it will be much better in the long run
    PilotGuy Guest
    Ok, ya i guess Ill do it myself, but where do I get those clips from?
    03ToyMan New Member
    hey even if you do let them fix it ask if you can watch, so if it ever happens again...
    clips should be over-the-counter at Toyota.
    Jersey City, NJ
    pretty much any place that will do bodykits and places that sell auto parts. check a local speed shop. they should sell them or tell you where to get em
    03ToyMan New Member
    I think I've seen a generic equivalent on those little red blister-pack "HELP" parts racks too.
    PilotGuy Guest
    ok update, I went to my toyota dealer and the guy looked under my car and said like a sliding clamp came off, and he had to special order it. Should be in by tomorrow, the cost? 74 cents! although i dont know about labor
    PilotGuy Guest
    WOO! :p :p I went there and the guy got like on his back with the part and like put it on and said it was free!!!!!! :D :D :D
    03ToyMan New Member
    Awesome! Chaulk one up for your dealership!
    yeye Guest
    if not done for freee, why not install urself? I mean its jus a clip... Look on your other side and u can see how it was attached :)...
