Engine help with tranny
Discussion in 'Powertrain' started by rainbow_star, Mar 20, 2006.
    you drive auto?
    jrtubrog3 Guest
    help with tranny
    my 02 prizm is not going into gear and I tried draining the tranny fluid and putting some new tranny fluid back in. what should I do? do I need a new tranny?
    jrtubrog3 Guest
    re
    yes I do
    jrtubrog3 Guest
    is it true that if you add to much tranny fluids your auto tranny goes bad ?
    corolla_racer Guest
    I don't think so man....
    How does it "not going into gear"?
    Do you feel like you're in "N" or what?
    jrtubrog3 Guest
    What to do
    does anyone know what I should do with the auot tranny? how can I fix this problem and get my prizm running? should I just replace the tranny and buy a new one?
    jtweezy New Member
    Irving, TX
    could be the torque converter
    jrtubrog3 Guest
    so i should just replace the torque converter.
    jtweezy New Member
    Irving, TX
    check it first....better to have it checked before changing the whole tranny
    jrtubrog3 Guest
    yeah it feels like it's in "N." how do you check the torque converter if it's bad or not ?
    I don't think it's the torque converter if you feel like it's in N. If the tq converter dead, the tranny can still change gear but just no power transfer to the wheel.
    Do you have tach on your car? Keep your eyes on it. If the tranny didn't change gear at all, you will see the needle go all the way to the redline. If it does change gear, you will see the needle go back a little, then go up again, then go back a little, then go up again.
    oops, I meant "tach" not "tech" :p
    I guess you have a bad tranny. The shop will charge you around 8hrs to do the tranny swap I think.
    jtweezy New Member
    Irving, TX
    8 hours??? damn it should only take 3 or 4
    jrtubrog3 Guest
    well I don't have a "tech" in my car, so i can't do what you said. but what if it redline, what does that mean? what wrong? what do I have to replace?
    ^yea, maybe with 2-3 ppl working at the same time.
    In order to take the tranny out of the 1zz rolla/celica, you have to take out almost everything (except the radiator and other small things).
    jtweezy New Member
    Irving, TX
    nope with 1 guy only
    RollaRyder1103 New Member
    Corona, CA
    i have a spare auto tranny for ya for cheap...it's freshly rebuilt and even overhauled. pm me, email me RuffRyder1103@comcast.net or im me on aim: s30zforce.
    pm sent as well
    pure rice Guest
    bring it to a shop to check
