Help troubleshooting a Honda
Discussion in 'General Discussion' started by 13oclock, Aug 25, 2004.
    13oclock Guest
    I know this is a honda post but since this is one of the only forums I trust and being a corolla owner I hoped you guys could help. My GF owns a 1990 honda and it won't run anymore. It has spark and gas is getting in it.
    It will turn over and it sounds like it is miss firing badly and is backfiring constantly. It will barely idle and usually has to be fully open throttle for it to run at all. The timing belt is new with only 20k on it and has never been a problem before now. Anyone have any help for trouble shooting? I am compression checking it tommorow. thanks guys
    APC_MATRIX_ Guest
    It sounds like a timing issue to me, check the distributor and such first :wink:
    13oclock Guest
    What am I checking for on the Distributor, I took the cap off but nothing looked burnt and what not.
    daveb91 Guest
    Fouled plug?
    Schoat333 New Member
    sounds like the timing is off to me
    APC_MATRIX_ Guest
    Did they install the timing belt correctly? If the head was not in synch with the bottom end, then the motor will run like crap cause the timing is off badly.
