HELP!! Sub/amp problem
Discussion in 'Interior' started by milhousse, May 20, 2005.
    milhousse C U in the car
    Winnipeg, MB, Canada
    I wired up my car for my amp yesterday, but didn't get to testing it until about 10 minutes ago.
    Powered it up, set up everything on my deck (sub out etc/etc). powered up the amp, and the sub is putting out almost NOTHING (even with volume and output and gain cranked).
    Changed out the interconnects - same thing
    changed out the speaker cable - same thing (even tried another speaker, so it's not the sub)
    Checked all the wiring, ground is fine (to brake light mount). turns on fine, internal fan is working, lights up etc/etc. Fuse is good (inline and on amp)
    Just can't figure it out. Does anyone have an idea?
    No, sorry, I've not gotten to that stage in pimpin out my rolla yet lol
    Strange, tho maybe it is a broke jack/output on the amp. Is there another one you could try? Maybe another amp lying around?
    I'm going to put in another amp when I get a chance to see if that is the problem
    laz Member
    NYC
    most likely your amp may be busted.
    X
    BangRolla New Member
    houston, texas
    well, your amp is powering up, so i dont think it would be busted.
    laz Member
    NYC
    Not necessarily, it can still power up and have the audio channels busted.
    X
    houston, texas
    hmm true. iforgot about that.
    well it powers up. lights up (power and other)
    get a little bit of sound (even if low or cranked)
    houston, texas
    reverse the polarities?
    as in negative to positive,positive to negative
    reverse the speaker wire
    Azn_SpICe New Member
    disconnect everything and do it one by one again?
    i checked the polarities on everything about 10 times to make sure.
    changed out the interconnects, that didnt do it. changed out the speaker wire -> same thing.
    Tried another speaker. tried new speaker cable.
    The only thing that I can think of is that there isnt a good ground. I'll give it a try tomorrow when it's light out. If not, guess I'll either have to sell my sub or get a new amp. kinda pissed right now about the whole thing.
    rice cracker VVT-i's Cracker
    Sacramento, CA
    he he he that's how it goes sometimes... :D I love all electronics but MAN, can they be frustrating
