Engine help quick
Discussion in 'Powertrain' started by slvr2000fdvspec, Sep 4, 2004.
    slvr2000fdvspec Guest
    did you disconnect your battery after the installation of the intake? try removing the negative from your battery for like 20 secs
    1.8greyghost Guest
    Ok, first off disconect the ground from the battery like stated above. You may just need to Reset your ECU. If this doesn't work, yeah you need some plugs, I recomend Nippon Denso, There good quality, good price, and there what Toyota uses in there cars from the factory.
    if the spark plug replacement doesn't work, get your motor decarboned.
    jox_rolla Guest
    help quick
    i need to know the best spark plugs avalible for a 98 corolla 1zz-fe i have a ram air intake and exhaust but im burning to much gas and miss-firing bad as hell any suggestions????
    Darkness Guest
    auto or stick?
    jox_rolla Guest
    jox_rolla Guest
    i got some bosch platinum 2's there similar to the factory ones im at 98 thousand miles and i think nothing has been replaces til me so im getting new belt im gonna get the aem pulley but im pulling my ac and my pwr steering and gonna find a smaller belt dont care i want all the power i can get b4 i get nitrous then later comes a turbo wooot
    the boschs took care of it but i still need wires and my sputterin is my muffler bc my friend with it on a neon makes the same noise
