Help on Raammat install
Discussion in 'Interior' started by velozmatar, Apr 22, 2004.
    velozmatar Guest
    Hey guys, I just got a bunch of Raammat in and i was wondering if anyone has a simple DIY to get me started? I have a huge roll, not a kit, so im not sure of what to do? I have no tools either, could someone help start me off? Thanks =P
    kwong2001 New Member
    Well basically, just make sure the surace is clean, i.e. no dirt. Then using a box cutter, cut the raammat to size and stick it on. The just go over it with a roller and repeat the process. Put it only on parts that are vibrating. I've found you'll get best results when you cover as much as possible on the vibrating part. Sometimes you'll have to do multiple layers.
