Engine help me prep for1995 rolla turbo
Discussion in 'Powertrain' started by oppositesleeper, Feb 6, 2006.
    oppositesleeper New Member
    Oklahoma City
    well basic fuel system is a must, injectors, fuel pump, and some sort of piggyback fuel computer to run it all together with.
    how much boost are you planning on running, that will tell a lot.
    mikenapril Guest
    I need to know what i need to do to my engine in a whole to get ready to put a turbo in it. I would appreciate any help, dont be a smart ass.
    las vegas
    dont forget oil cooler just to keep your oil not boiling too hot.
    corolla_man_j Guest
    gauges, you are going to need a wideband UGO, and others to monitor boost, and temps, also if money isn't too big an object, you should get pistons, rods, and sleeves
    mikenapril Guest
    What kind of turbo do you have in mind?
    corolla_man_j Guest
    wow, starting with 12 lbs of boost, you are going to have to sleeve, do pistons, rods, valves, cam, fuel, oil, not to mention the axels, and tranny
