Help! Installing M3 Mirror with LED on 01 corolla!
Discussion in 'Exterior' started by SystemWorks, Nov 17, 2004.
    SystemWorks Guest
    hey guys.. as the title suggest, i need some major help on installing it on my 01 corolla, it came with NO bolts so i was wondering wut kind i need if any of yall have experience installing it.. secondly, i believe (correct me if im wrong) the corner lamp on my 01 corolla have three wires: signal+, light+, and ground. so if i want the mirror LED on ONLY when im flipping on the turn signal or hazard light i just connect the wires to signal+ and ground? i did try that but unless i did it wrong the LED stayed on whenever i flip on my corner and blinks off whenever the turn signal is activiated. so does that mean i need a reverse thing (i dont know wut it is called =_=).... so please guys help a newie out!! :)
    SystemWorks Guest
    ok.. hmm so now you have all three wires hooked up? so i assumed that both the amber and the blue works but one of the color blinks and one is constant?
    SystemWorks Guest
    jiggaman725 the black guy
    Ellicott City, MD
    As far as the bolts, take off your stock mirrors, take one of the bolts out and take it up to a hardware store or wal-mart or something and get new ones that are around the same size. I tried to use the ones from my stock mirrors but I ended up fucking it all up and wasted alot of time.
    About the LED...I'm not sure if you can have it only come on when you hit the turning signal. Mine is always on when my lights are on and the blinks opposite my corner lights (when one's on, the other isn't)...I think I made a thread about how I wired them when I finally figured it out...just do a search and you should find some stuff
    steve403 New Member
    Ellicott City, MD
    yeah i have all 3 hooked up...i'm not sure if i got the ones where you have a choice between a blue or amber led, but mine are always amber...once i finally got it working i really didn't feel like messing with it anymore...plus i don't wanna risk getting pulled over for having the blue ones
