Headlight Reflector
Discussion in 'Exterior' started by bewildered_spruce, 2003年11月02日.
    bewildered_spruce Guest
    Headlight Reflector
    Hey guys, my car's leased and i talked to a guy at the dealership who told me that i can do anything to my car as long as it's returned to stock when i bring it back at the end of the lease. So i was wondering if anybody happened to know if it's possible to get the lense off the headlight so i can take the reflector out without destroying it. Any help would be very appreciated. Thanks.
    yeye Guest
    Yes you can but it would be wayyyy to much of hassle cuz u would have to take ur headlight apart and then reseal them...
    Toyo_Toy Guest
    Anyone have a picture of the lenses taken off?
    What's the benefit/use of taking it off... Thanks!
    ph0bi4 Guest
    It looks a lot better. Heres a pic of mine with no reflector:
    CorollaAltis New Member
    i do. check out my sig and avatar
    OC Rolla Guest
    Re: Headlight Reflector
    You could just buy a used set of OEM headlights from someone or off ebay to use when you need to return the car. I know this method requires money but not the hassle of opening your headlights like someone has already mentioned.
    Toyo_Toy Guest
    Ooops, he meant the yellow reflector... I was thinking the reflector behind the bulb... :oops:
    I have to re-read his post again... :lol:
    Anywayz, that looks sweet without the yellow reflector!
    Hey, what are the chances that I'm going to screw it up if I do it?
    What's the worst thing that could happen?
    Thanks!
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    you can end up scratching up the whole inside which will look bad other than that, you may snap the tabs that hold the hlight in place if you dont do it carefully when installing and removing the assembly
    Toyo_Toy Guest
    Sigh... What's my alternative? Can I buy similar headlights without the reflectors (Altezza maybe)?
    Thanks!
    Jersey City, NJ
    i've only seen the blackhousing ones. saw the clear ones on ebay when the 03 first came out, havent seen them since
    Toyo_Toy Guest
    D@mn! I really like that looks of that (without the reflector)...
    I think the main thing that's me holding is the part where I pull out the headlight out of the car... Too many bolts and stuff to pull out...
    Is there a way, I could take out the yellow reflector without taking out the headlights out of the car?
    Hmm, I wonder... coz' I dont think you will need to take out the whole housing when the bulb dies... You guys know what I mean... Let say, the yellow bulb burned out, I can replace it without taking the whole thing out, right?
    I gotta go check, or let me know if you guys already tried, and it's a no go...
    Thanks!
    OC Rolla Guest
    You don't need to remove the light to change bulbs. The only method I know of removing the orange reflector without openiing the light involves breaking it and pulling it out through the turn signal hole. I'm not sure if you can fit tools into the turn signal hole and break the reflector off without removing the headlight. Seems like there isn't enough space in the engine bay but take a look, maybe you can.
    If you want to go with my previous suggestion of buying an extra set of headlamps... here is an auction for you. :D
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33710&item=2440077397
    SSJ_Rolla Guest
    If u lived in Cali I would cleared out ur orange piece for free 8)
    thanks for the input guys... is it my imagination or do those headlights look less chrome than the oem?
    Toyo_Toy Guest
    hehehe, Here's another reason it suck to live Hawaii!
    I think I'll try pulling it out this weekend... :twisted:
    OC Rolla Guest
    Which lights? If you mean the ones in the ebay auction.. the pic looks kinda crappy to me so I can't really tell what's up. I know that the plastic headlight housing on the S is slightly smoked compared to the clear CE/LE headlights.
    ph0bi4 Guest
    If you mean the lights in my pics, its because in the close up pic, the car was dirty and dusty. In the distant pic, the sun wasn't hitting it, so it wasn't very shiny.
    SSJ_Rolla Guest
    If I was going to Hawaii, anytime soon I will hook u up
    heres mine done:
    took me bout an hour but the timing to cler them out has shrunk to 45 min :D
