headlight conversion info needed
Discussion in 'Exterior' started by Artist7, Nov 1, 2004.
    Artist7 Guest
    i was wondering has anybody converted their 2002 headlights to the headlights of a 1998-2000 rolla.. i was planning on changing my kit to one from the earlier models so now i need a lil info on swapping the headlights.... will i need a new wire harness and if so, where would i find one.next, could i get away with having the same hood and fenders or would those have to be replaced also? plus if anybody knows where i could get headlamps and corner lenses for cheap that would be also very helpful..thx
    sddynamix Taybo Masta
    La Jolla, CA
    Correct me if I'm wrong... but all I think you'd need is the following:
    98-00 headlamps and corners
    98-00 bumper/or kit
    you will need an H4 harness, i'm sure you can find these at an autoparts store. you should be able to connect the low/high beam wires to the harness and combine the grounds.
    i'm not sure if the mounting points for the headlight brackets are the same, you might want to get two full assemblies w/brackets
    corolla81386 New Member
    you can get the lamps with mounting brackets and clear corners off ebay.. H4 harness i got at oreillys.. the conversion is a bitch to do.. i used the same fenders and hood
    sxlostv1 New Member
    Los Angeles
    RollaRyder1103 New Member
    Corona, CA
    i have some headlights i can sell u as well as corners (clear or oem), I'll sell u the headlights (even throw in some aftermarket bulbs) for $120 plus shipping (only used them for like 3 months then bought another set that I did the retrofit on)...plus the clear corners or oem corners for $15 plus shipping...let me know
    slvr2000fdvspec Guest
    care to explain why it was a bitch to do?
    because the lights and corners dont fit right.. its hard to get everything to mount right and the wiring isnt straightforward
    Speed_Racer Guest
    PM deathsight. He has a thread wanting to do a conversion from 98-00 to an 01-01. Both of you could basically just swap parts and both conversions be complete.
