Engine headers for my prizm
Discussion in 'Powertrain' started by Projekt_Go, Feb 12, 2008.
    Projekt_Go Guest
    im looking for headers for my 1994 prizm lsi. any suggestions on to where i can find any?
    05 TRD SCed Guest
    ebay has them. I believe, if not mistaken, your car has the 7afe 1.8l or the 4afe 1.6l. Your car should use the same header as the 94 corolla with the same engine. the prizm is really a toyota corolla with some style changes and different badges.
    Since you have the 4AFE, the 4AGE(AE86 Corolla) header will fit. A lot of aftermarket companies make them. TRD also has a header available, although they are a bit pricey.
    jcrwzr Member
    Simi Valley, CA
    did someone say headers?
    05 TRD SCed Guest
    The 4age header won't work on the 4afe, it has a different flow design just like the 1zzfe header for the 04-05 Corolla with 2zzge won't work on the 04-05 1zzfe. they have different flow. The header for the 4afe flows the #1 and #4 together and the #2 and #3 together. On the 4age header, the #1 and #2 flow together and the #3 and #4 flow together. the tuning is totaly different. And there's no way the 4age header for the AE86 would fit. The AE86 is rwd and the 94 prizm is fwd. That's just another reason why the 4age header won't fit unless you modify the h** out of it...lol. If you have the 4afe or the 7afe, which where both options for the year, then you should be able to find a header on ebay for it. But make sure that you get the right one for the engine you have. There are differences between the 4afe and 7afe header and you could have issues with fitting it if you don't get the right one.
    05 TRD SCed Guest
    <br />
    Ya. Someone said that word, header again....lol.
    las vegas
    its spelled h*e*a*d*e*r minus the s,lol...unless your car is a v6,v8,v10 and v12 and now you can call it headers because you need more than one header.
    Legit01Rolla Active Member
    header!header!header!header!header!header!header!h eader!header!header!header!header!header!header!he ader!header!header!header!header!header!header!hea der!header!header!header!header!header!header!head er!header!header!header!header!header!header!heade r!header!header!header!header!header!header!header !header!header!header!header!header!header!header! header!header!header!header!header!header!header!h eader!header!header!header!header!header!header!he ader!header!header!header!header!header!header!hea der!header!header!header!header!header!header!head er!header!header!header!header!header!header!heade r!header!header!header!header!header!header!header !header!header!header!header!header!header!header! header!header!header!header!header!header!header!h eader!header!header!header!header!header!
    But I have headers. I have my Forza one installed and my stock one sitting on the floor of my garage. Does that count? LOL :D
    jcrwzr Member
    Simi Valley, CA
    i dunno... i guess you can say that your car still has a header, and you have a spare header stored in your garage.
    but, it's perfectly okay to say the following example,
    Check out Summitracing.com! They have a wide selection of 4-2-1 and 4-1 headers for practically every vehicle!
    or
    Hooker headers have a long tradition of being loud and the most free flowing. Inquire at your local automotive parts dealer!
    Projekt_Go Guest
    yah i gots a 7afe.
    Projekt_Go Guest
    whats better to get? ceramic or stainless steel???
    I say stainless because ceramic coated is usually made of mild steel with a ceramic coating. If/when the ceramic coating chips off the steel would start corroding/rusting.
    jcrwzr Member
    Simi Valley, CA
    i go stainless
    ^^That's true. I guess you can always heat wrap it if you want the insulating properties of a ceramic header.
    05 TRD SCed Guest
    Go for the stainless steel especialy, if you purchase it of ebay. The ceramic coated ones on ebay are crappy, the ceramic coating will flake off in a matter of weeks and all you'll end up with, is a ugly a** rusted up header. Trust me, I know from experience.
