headers and unichip..where?
Discussion in 'General Discussion' started by postman8685, Jul 9, 2004.
    postman8685 Guest
    where can i buy a uni chip and racing headers...also is the unichip worth it, can u feel the differnce in power?
    RollaS New Member
    jp performance makes some good headers...........Unichip isn't worth the money unless you've got a good amount of mods and a good place to get it tuned.
    ultraviolet Guest
    I partially agree with this.
    Heres my .02,
    I have the Unichip with a pretuned map for CAI/Exhaust on my Matrix XR auto. When I added the Unichip, the power increase was not mind blowing. The Unichip is not tuned for peak horsepower and torque, but for a total increase across the entire powerband. The highest gains are in areas of the powerband that the engine is lacking. With the Unichip on my car, you can definitely tell a difference. The car runs crisp and pulls alot better from 3500 to 5500 rpms. I even took the Unichip off my car for a day, and quickly realized that my car was not as responsive and fun to drive.
    If your interested in a Unichip, pick one up used and get it re-mapped from Unichip to match your mods. I feel that the cost of a used one is worth the gain.
    If you are going to add a header, SC, or anything else, you can always go for the custom tune if there is a Unichip tuner in your area.
    APC_MATRIX_ Guest
    Well said, a used one is worth the cost but not new.
    I'm lucky though cause I can have Jack's shop (the owner) tune my car when I get one :D
    Blk03Corolla Guest
    Well the one benefit that you have is that I have a map made following each of my mods so if you want to go all out you will be able to have maps for your car. Once you get i/e/h it would be worth it at that point. You would of spent close to a grand on that work and would double to perfromance out of it by spending another 700-800 with the unichip
    postman8685 Guest
    so how much hp do we gain and were can i buy one?
    Blk03Corolla Guest
    You can order one from Unichip directly and un terms of gains I think I would put you around 160 to the flywheel with CAI, Header, Exhaust and unichip. Without the Unichip you would probably be around 145. Anytime you change the air flow in the car the ecu doesnt understand so you dont get full potential out of the mods you do. The unichip will fix that though.
    ultraviolet Guest
    There is 2 Matrix guys selling their Unichips right now!
    Mine will be for sale very soon, only because I'm getting the SC.
    APC_MATRIX_ Guest
    Too bad I have no money :cry: :cry: :evil:
    postman8685 Guest
    are they easy to install, like a DIY
    brownbanana ToadMotorSports
    Oahu, Hawaii
    too bads theres no unichip dealers within like 3000 miles :shock:
    wi rolla Guest
    Hey-whos selling the unichip on matrixowners? Also, is there a unichip tuner in the wisconsin/illinois area? How can I find this out?!?!?! Will this mod be any good with my intake/header/axle back, or do i need the midpipe as well???? Should I get the unichip first or the JP midpipe??? HELP ME PLEASE!!!!
    ultraviolet Guest
    Here are the 2 sellers:
    http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&t=26502
    http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&t=26675
    You can contact Jack Friedman at Unichip North America to find out if there are tuners near you. jack@unichip.us
    If you are considering going with one of the pre-tuned maps from Unichip, then I would NOT get the JP midpipe, because they havent set up a map for that combo. If there is a tuner near you, then get the JP midpipe and get a custom tune done.
    The Unichip is very easy to install and comes with complete instructions.
