Head Light Aim Adjustment for 01~02?
Discussion in 'Exterior' started by mingww, Feb 18, 2005.
    mingww New Member
    Vancouver, B.C
    I'm wondering that will I be able to adjust the head light aim for my 01?
    i don't see any where that i can adjust it...
    anyone know?
    Thanks in advance!!
    Ming
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    I dont have a 01-02, so I dont really know. But Im pretty sure there should be a screw for you to change the aim, it shouldnt be too hard to find. I found it on my 00 and 05's headlight.
    Tamago New Member
    there's an 8MM bolt on the back of the headlight, that you can put a socket on.. also, the edge of the bolt is "fluted" to allow for a screwdriver to be inserted from above and rotate.. (but it doesn't work too well) . use the 8MM ..
    mingww New Member
    Vancouver, B.C
    ah^^..i will try to look for it~..
    thanks you!! :D
