Engine Has anyone tried using 7MGE injectors in their 1ZZFE?
Discussion in 'Powertrain' started by Dr Tweak, Feb 4, 2006.
    Dr Tweak Mad Scientist
    Savannah, GA
    Did they fit? What year is your engine?
    -Doc
    jtweezy New Member
    Irving, TX
    they work great!!..thats what i'm using right now.
    Savannah, GA
    What year is your engine, did you have to make any modification for them to fit, and can you please take a pic for me?
    -Doc
    were they a tight fit into the head?
    toyotaspeed90 New Member
    Bellingham, WA
    most toyotas have roughly the same size injectors (physically that go into the head and into the fuel rail), unless they're sidefeed of course
    1zz injectors series were a LOT smaller in size of diameter. they are uniform up and down the entire length of the injector, not large at the top then staggered down.
    jtweezy New Member
    Irving, TX
    I have the 1zzfe 1.8L non vvti...and didn't have to modify them at all ....the car idles fine with these injectors and with the emanage settings at 0... I got them at a junkyard for $40 with pigtails. I dont know how to upload pics on to the forum so heres a link and scroll down to the bottom of the page... http://www.cardomain.com/ride/2137200
    Savannah, GA
    Yeap, those are the ones. So they fit fine huh? Well, that's one '98 and one '01... so I guess they do fit. I'll have to try it myself next month.
    -Doc
    fastrolla96 speedbumps..yum
    Oklahoma
    so how about for the 93-97 corollas, what injectors would fit it from another toyota? I'm wanting to make as much power as I can on a N/A setup for right now.
    Savannah, GA
    Any top-feed Denso injector used in any Toyota will fit into that series. The 7MGE are a good choice for a low-boost turbo setup.
    -Doc
    oppositesleeper New Member
    Oklahoma City
    whats a good donar car to get those injectors out of?
    and what cc do they run?
    jtweezy New Member
    Irving, TX
    88-92 cressida.....315cc
    Bellingham, WA
    also:
    4agze (any:( low ohm 366cc/min
    4age: blue - low ohm, 210cc/min
    4age: tan - low ohm, 230?cc/min
    4age: green - high ohm, 250cc/min (will work with a stock 4afe/7afe ecu)
    7mge: yellow? - low ohm ???cc/min
    7mgte: black - low ohm 440cc/min
    Also, not sure what size they are, but the 5sfe, 3sge, and 3sgte injectors are higher flow injectors than a stock 4/7afe setup.
    jtweezy New Member
    Irving, TX
    7mge injectors are either yellow or light green....use the light green injectors..
    Corolla DX-R AE100
    Vancouver, B.C.
    sweet time to go to the junk yard...
    tunerperformance New Member
    florida
    i have a ? i asked one of the guys at my work hes a camaro guru i asked about bigger injectors on my 03 corolla withj a bigger full pump he siad unless you have a turbo or super charger its a waste cause your not going to burn all the fuel you wont get any extra power
    Oklahoma
    So what is the stock flow for a 7afe? I'm thinking of getting the 3sgte or the 4age one cause there's a couple at this junkyard I know of.
    ChristianVA New Member
    yup just wasting gas.
    Savannah, GA
    The 4AFE are 176cc (grey-tops), I expect the 7A to be marginally bigger. There are severl different ones for the 4AGE, beige are 213cc, green and violet are 250cc. You can't use the 3SGTE ones, they are side-feed.
    -Doc
    Oklahoma
    sweet thanks for the info. Would the fuel rail on the 4age fit the 7afe also?
    Savannah, GA
    I don't know...
    Oklahoma
    Huh! that's the first I see you get stumped. :D
    Savannah, GA
    Heheh, well, there's just no need to swap them so I've never tried. Ask toyotaspeed90, he might know.
    -Doc
