halo light bulbs
Discussion in 'Exterior' started by chino_h80, Jan 31, 2005.
    chino_h80 Guest
    halo light bulbs
    what are the codes for the projection headlights? 9006,9005,H3?
    KingKuei Guest
    FYI, the projects use H3 bulbs for low beams and H1 bulbs for high beams, with modified wiring harnesses that adapt to the stock 9006 and 9005 wiring.
    Light output is absolutely horrible without an HID upgrade (my foglights are brighter than the projectors). Once HID upgrade is in, you can also upgrade the wiring harness to allow for higher output H1 bulbs for your high beams.
    My setup:
    Projector headlamps
    - Honda S2000 HID retrofit (currently being done by distantxtremes www.powerplayhouse.com/dk2/diyhid.html) with modified cut-off beam
    - On order, Philips Vision PLUS +50% ECE H1 bulbs
    - Sylvania SilverStar turn signal bulbs
    - Swapped in HyperWhite city light bulbs
    - Upgraded 9005/9006 heavy duty wiring harness
