Engine guys help me decide
Discussion in 'Powertrain' started by sean2sean, Aug 19, 2004.
    sean2sean Member
    so cal
    i havent heard of any other corolla owners installing other turbo kits besides the sf one.
    personally... i like the kit i have on my car.
    BigDaddyC Guest
    i doubt it matters but mines a 01 model i have found the garret at landspeed racing a one at turbo kits.com and one more but i forget were right now i dont know if there exactley the same one think nos is what i might do unless someone tells me different. so hard to decide
    sean2sean Member
    so cal
    if i wanted to buy something... i would buy something that other ppl already have... unless u live right next to them and can figure out the problems rite there and then...
    go with sf...
    BigDaddyC Guest
    guys help me decide
    turbo kits a coming but which one ive found like four (but it seams most are the same one but sf or the garrett turbo kit....or should i throw on a 50 shot
    ive been decinding for like the last month i just would like some input from u other guys thanks
    thespud Guest
    Have a good read of this thread:
    http://vvti.net/forums/showthread.php?t=3618
    These are the dangers of sf... I will say tho, whatever you do, be very careful where you drop your $4k on a turbo kit... and make sure it is done properly... or failing that... do it yourself.
    2krolla New Member
    Birmingham, Alabama
    Im still new to all of this. However from what I have come across I would say go with the Garrett turbo and maybe the 50shot of spray to get the turbo spooled up.
