Grounding?
Discussion in 'Interior' started by rob, May 9, 2003.
    rob Guest
    Grounding?
    Has anybody found a suitable place to ground the amp in the trunk of the 03 rolla?
    SSJ_Rolla Guest
    i found a place where the back seat meets the trunk
    methaneb Guest
    I drilled holes in the bars that seperate the back seat from the trunk... my amps are mounted on my back seats.
    michaelcorolla Guest
    anywhere close to the amp location will work. sand the paint off down to bare metal for a better contact. Use a lock washer for a tight connection. Wach were you drill for gas tank and brake lines. short ground wire is better and should be samw gauge as poer wire.
