Grounding amp in the trunk
Discussion in 'Interior' started by BriCubz, Jul 26, 2004.
    BriCubz Guest
    I understand that this is probably a newbie question, but does it matter where in the trunk I ground an amp to? Can I attach it to any random unpainted bolt, or is there a specific place that is recommended?
    Also, I attempted to make an account on CarDomain.com so I could post some pictures. But they never emailed me my temporary password. Anyone ever had this happen? I tried again and now it tells me that my selected memebr ID is being used already. Which is true, it's being used by ME. But I have no password. Oh well.
    Thanks in advance for you help.
    BriCubz
    shortys408 Guest
    i grounded to the frame of hte car. ground somewhere near where u want to mount ure amp because u want hte ground wire to be as short as possible
    whosnext Guest
    Good luck trying to find a good grounding location. I've been trying to find onr for a whiile....maybe common sense is not working in my favor. I'm open for any ideas for a better mounting location in the trunk.
    shortys408 Guest
    it took me a week to figure out my ground was good but i never connected the other end of hte remote turn on to the head unit :oops:
    superakuma Guest
    When you are grounding the amp make sure you scrap off any paint on the chassis to get a better ground. If you are grounding 2 or more amp in the same location, put the more powerful amp ground on the bottom closer to the chassis
