GROUND
Discussion in 'Interior' started by shortys408, Mar 15, 2004.
    shortys408 Guest
    GROUND
    im getting frusterated i cant find anywhere to do the ground . I cant use hte tailight bolts or the trunk latch because my ground wire isnt long enuff to reach teh amp.
    bimmernut Guest
    Huh? For what?
    PsyVash Guest
    I'm guessing he means for his system. If you're looking for a place to ground, ground it to the tail light bolts. It isn't that expensive to go buy new wire.
    brownbanana ToadMotorSports
    Oahu, Hawaii
    yea, not a lot at all
    Sasuke Guest
    ground anywhere make sure it stick to the car frame ahah
    03landorolla Guest
    I know your problem, cause I think the ground is supposed to be no longer then 3 feet long, so you are sort of limited to where you ground it too. i had to ground it to the latch bolt, but had to put the amp in a place i didn't want. If I am wrong about the ground length, please let me know!
    shortys408 Guest
    is there n e where like under hte back seats.
    polo708 New Member
    9thgencorolla.com
    I've always been told the same thing... no longer than 3 ft.
    shortys408 Guest
    ok this is so weird and makes absolutely no sence but hte ground works i got a working ground. but when i tighten the ground on the amp it turns off. is it possible that the plate isnt good or something i've run out of ideas.
    shortys408 Guest
    my ground is 4 ft long :oops: is htat a possibility y it doesnt go on all the time?
