Engine Ground Wires???
Discussion in 'Powertrain' started by 4pinks, Mar 17, 2007.
    4pinks New Member
    Ground Wires???
    Hey Pipz! I Just Want To Know If Someone Here Installed And Experienced Thick Ground Wires With Or Without The Voltage Stabilizer???
    Have You Noticed Any Difference In Engine Reaction,is The Engine Much Quieter,did You Get Better Fuel Economy And Brighter Lights?
    I Would Like To Install One Next Week If You People Liked How It Worked....
    Thanks.
    dward3 Well-Known Member
    Phoenix
    I have both the Hyper Voltage System and Hyper Ground System installed. It doesn't give you significant gains but it does make shifting a bit smoother and gets rid of the dimming headlights and accessories. It might actually make a little power but it's not really noticeable. I didn't notice much difference in mpg. Overall, it's just a good thing to have to increase efficiency and to prevent corrosion of the battery terminals and other buildup from different metals in the car reacting to form deposits.
    Corolla DX-R AE100
    Vancouver, B.C.
    i got the Pivot volt stablizer and Pivot grounding kit...
    what i've notice is:
    -subwoofer hits harder and lower
    -lights can't tell cuz i got HID
    -tranny shift smoother
    -easier engine start
    -my a$$ dyno feel a bit faster acceleration but after awhile u'll get use to it...
    -light bulbs last longer then normal
    -gas milage abt the same
    -less corrosion and build ups on battery terminals
    -idles quieter and smoother
    -a/c works better imo...
