Engine Ground wires really do make a difference..... surprisingly
Discussion in 'Powertrain' started by Schoat333, Aug 18, 2004.
    Schoat333 New Member
    i installed some ground wires on my car today not really believing they would make any difference but they really do make the car run smoother and more responsive especially at low RPMS. not like more powerfull or anything just not so lurchy. heres a pic and go to my page for some more.
    04MGRolla Guest
    how much did i cost?
    i payed 30 bucks shipped off e-bay. not a bad deal it come with 7 wires 2 long 2 medium and 3 short plus the adapter anf the plate that goes on top... the TRD logo is just a sticker... not real TRD obviously but looks good so i put it on.
    Killercocopuff New Member
    SoCal
    I just got that same exact kit and installed it yesterday. I dont feel any more power or torqu e as it claims and my head lights dont seem brighter. but my auto does shift more smoother. and it looks good in the engine bay. o well this is just a temporary solution till i get the Apexi grounding system :D it supposedly gave an evo 9 whp
    TheBeak Guest
    i dont know how much diffrence your going to see by upgrading from one brand wire to aother.
    9hp on a 300 horse motor is only 3%. your probably getting 3% out of yours, its just not enough to test on the butt dyno.
    i have a set of grounds made by another forum member and saw lots of little subtile improvements. worth 30 bucks. not worth 100 or more.
    yea i doubt you really getting more power out of it... the car just runs smooter which give the illusion of more power when its really only different then your used too. im gonna put my underdrive alt pulley back on and see if i notice any difference.
    SoCal
    4/26/2004
    A'PEX Super Ground makes 8.5 HP
    We are pleased to announce that during a recent dyno test for D-Sport magazine, the new A'PEX Super Ground System made an outstanding 8.5 horse power to the wheels. Testing was conducted on a 2004 Subaru WRX STi using XS Engineering's four wheel chassis dynamometer. Previous modifications to the car consist of upgraded intake, downpipe, exhaust, and front mount intercooler. Power output was increased throughout the power band with a maximum gain of 8.5hp at 6000 RPM (400 RPM sooner than baseline max power). This test proves the real world capabilities of the Super Ground System.
    For purchasing information, please contact an authorized A'PEX distributor (see "dealers" section of our website for a complete nation wide list).
    Car: 2004 Subaru WRX STi
    Modifications: Upgraded intake, exhaust, down pipe, front mount intercooler
    MAX POWER (Baseline:( 298.1 @ 6400RPM
    MAX POWER with A'PEX Super Ground System: 306.6 @ 6000RPM
    Power measured at all four wheels using four wheel chassis dynamometer.
    *Just if you wanted to read it also the Apexi one has a box that supposedly and i quote"the control unit features an electrical charging system and electrical noise filter. The double noise filter smoothes turbulent electrical current, providing a stable and consistent voltage flow to all your vehicles electrical devices
    TheBeak Guest
    another example of a 3% gain. just remember your not going to get 9 horses from this on our little power plants.
    skyy Guest
    could you post more pictures? where do you connect all that cables to?
    polo708 New Member
    9thgencorolla.com
    click the link under his sig... there are more pics there.
    i tried to go by what they said to do
    the first wire wraps around and goes to the bolt that holds down the headlight
    second goes to the trans. i used the same mounting bolt as the O.E. ground
    third wire goes to the head.... there is a bolt by the quick disconnect for the fuel rail that holds a bracket to the head.
    fourth wire is 2 pieces the first piece goes to the bolt that holds a bracket to the throttle body and intake and then the second piece goes to the A/C compressor
    fifth wire goes to the alternator top mounting bolt
    finally the sixth wire is going to the front motor mount
    04MGRolla Guest
    Any idea what gauge wiring that is? Might try making my own. :D
    SoCal
    4 i think and some guy on the celica forum made his own and sold them there
    yea the ones i have are 4 gauge. custom is a good idea because the longest wire i got with my kit barely makes it to the alternator. thats why that one wire goes over my intake. that was the only way that it would reach.
    skyy Guest
    does it make any differences in manual transmission?
    i have a manual trans.
