Engine Ground wires on the car (pic added)
Discussion in 'Powertrain' started by TheBeak, Jun 28, 2004.
    TheBeak Guest
    not much to see in a picuure, just a few 4 guage wires strung around the engine bay. so no new pic right now....
    results: well worth the 30 bucks and an hours time it cost.
    1) easier starting. you know how you get used to how a car starts (rev, rev, rev, vroom....) it catches me "by suprise" every time now (rev, rev, vroom)
    2) smoother idle. less "hunting" for an idle speed.
    3) smoother power through the mid range. less hesitation, especially noticible during clutch let out. if I let out a bit too soon (not enough throttle) where id get a hesitation before i now get smoother power.
    APC_MATRIX_ Guest
    That's exactly what I noticed, not really a power gaining mod, just a smoother engine 8)
    RexPelagi VDub
    Canton, Ohio.
    Wait what exactly is this?
    dominator 04 Rolla 5spd.
    It's a ground upgrade... I've had great results from replacing the thin stock crimped battery ground cable splitting to the engine and smaller wire to frame, for a soldered #1 gauge wire to the larger ground bracket bolt on top of tranny, and a #4 gauge wire to frame (sanded down to bare metal), under battery.
    Easier starting, idle is more stable, better electrical output, and I swear I got more torque and power, which is what impressed me the most for a $27 custom upgrade. I will now upgrade the frame to engine ground. (front of tranny to driver's side strut chassis)
    TheBeak Guest
    dug up a picture:
    wire is run from battery ground to body/frame, battery ground to tranny, tranny to head, head to the other side of the head, other side of the head to body/frame.
    this was shot during the install, the engine cover is back on now.
    the picture also shows the $2 A/C mod, also highly worth the time and trouble.
    pkpss Guest
    A/C mod ?
    TheBeak Guest
    adding insulation to the cold side of the A/C line from the compressor to the firewall.
    polo708 New Member
    9thgencorolla.com
    sweet idea, never thought of it for some reason :?
    nikeair11 Guest
    I think I'm going to do this now too. What brand of groundwires did you use?
    TheBeak Guest
    PBR brand :)
    got them HERE but you could probaly make your own. some four guage wire, ring terminals and some time and bang, your grounded.
    i believe that PBR will still make a set or two to order, if he had the materials anymore...
    tom Guest
    Maybe insulate the intake pipe too to prevent the pipe from heating up too much. I'll be looking foward to the ground wires DIY.
    imported_FUSIONLE Guest
    WILL 4 GAUGE STREET WIRE WORK FOR REGROUNDING MY RIDE . I HAVE SOME THAT WAS USED TO RUN MY AMPSIN MY OLD CAR . IF NOT WHAT SHOULD I USE ?
    4 gauge is good... You want to start by improving the ground right at the source with a heavy duty battery ground terminal connector that is soldered to preferably a #1 gauge wire to engine and a #4 gauge frame ground wire, both with soldered terminals. You can also upgrade the engine to frame ground wire.
    Misinformation Police Guest
    Re: Ground wires on the car (pic added)
    So now it's ONE less "rev"... all that wires only to minimize ONE "rev".. :lol:
