Engine Ground points
Discussion in 'Powertrain' started by Silver_Nitrate, Mar 31, 2005.
    Silver_Nitrate New Member
    Ground points
    I'm going to run new ground wires on my 99 corolla. Anybody know or have a picture of the different ground points on a 99 corolla? I get the wires at work pretty cheap so I I'm thinking about either replacing them or adding ground wires to them.
    teevee247 Well-Known Member
    Montreal, QC
    Replace your current ones... you should see them all in your engine, basically they are going from your block to different areas in ur engine bay... just replace those with a high quality wire... maybe 12~10 gauge...
    toyotaspeed90 New Member
    Bellingham, WA
    why........ as long as your current wires aren't having problems.....
    BangRolla New Member
    houston, texas
