grill honeycomb
Discussion in 'Exterior' started by Pred, Jun 3, 2004.
    Pred Guest
    grill honeycomb
    The honeycomb lets say, on a matrix or on a camry for the front grill.. where can i get some material like that without buying another grill or something?
    my mesh that i got with the altis grill is fading from all my highway driving... thanks
    Concordmk1 Guest
    OT: How'd your ticket turn out?
    Pred Guest
    i'll PM ya about it... on with the subject!!
    Pred Guest
    most excellent.. thanks for the links so much!
    juice916 Guest
    I was looking for the same thing!
    toyotaboy New Member
    lith, IL
    gutter material has an almost honeycomb look to it. You can buy true honeycomb material from mcmaster. See this thread:
    http://www.vvti.net/forums/showthread.php?t=292
    If getting a matrix grill is too expensive, you can buy honeycomb composite sheets from Mcmaster:
    http://www.mcmaster.com/asp/DisplCt...cMMainWidth=716
    1/4" should be thick enough? Might have to buy a full 2ft though (Make two grills, then sell one.. or honeycomb mesh something else).
    They also sell aluminum diamond plate that make pretty cool industructable floor mats if you know what you're doing (just have to trace stock floormat and create a bend in the right place)
