Engine Got my ground wiring kit, need help
Discussion in 'Powertrain' started by killer2239, Jul 14, 2004.
    killer2239 Lift at 5700rpm
    Lexington, KY
    Ok, i got my ground wiring kit. What are the things i need to reground. Im not exactly sure what gets grounded.
    SkyAce2004 New Member
    negative battery terminal, frame of the car, alternator, intake and exhaust manifold
    IM me: skyace2004 if u wanna see pix of mine
    NOT the exhaust manifold. Do everything he said except that. I think the way the ground is this in order: Frame, intake manifold, block, tranny, negative terminal, and frame again. If you want you can also ground the alternator if you have enough wire. The exhaust is a bad idea cuz it gets really hot and could melt or cause a problem. i don't think current can travel through a heated material easily, the resistance is increased dramatically.
    yup rollatuner has it right and in the correct order.. the alternator on the 93-97 however does not have a ground wire, I think it's grounded to the engine by way of the bracket
    Lexington, KY
    Thanks guys, im hoping to install this tomorrow or saturday morning.
    thespud Guest
    93-97's blocks are grounded on the left (as your looking at it) thru a wire that runs to the frame from the intake manifold.. anything on the block or tranny is grounded thru that wire because oviously electricity cant get thru the rubber mounts.
    ive got 4 guage on my exhaust manifold and there hasnt been any problems...
