Got me an RS front lip!
Discussion in 'Exterior' started by GSE21tuner, Jun 10, 2007.
    I can't wait! I've always wanted one but the one supershyguy has for the 98-00 was fugly IMHO. I came across this and I knew I had to have it.
    There's still one more being sold by this seller. They allow for local pick up so I'm gonna pick it up after I'm contacted.
    And there's another seller but based in Canada.
    I compared to the pics of the shyguy front lip.
    The other is so much sexier. hehe
    Can someone photoshop the lip above to the first shyguy lip pic? Its at the same angle.
    Tulsa, Ok
    both of those lips look pretty good...that could persuade someone not to do an 01-02 conversion..
    I'm glad I never did the conversion.
    I just picked up the lip. Its exactly like how it was described. I'll install it and post pictures later.
    BEFORE:
    AFTER:
    rolla_7AFE hmong
    sacramento
    not bad .are u gonna leave it black???
    Yeah. I'm going to paint the skirts black too. And I got rear mud guards which I'll paint black as well.
    plu Well-Known Member
    SC
    So with this lip, you had to cut the bottom of the stock bumper to fit it? I know you cut the stock bumper a while back, but can this lip fit the stock bumper if the bottom piece wasn't cut? And what is tthe material used in the lip strong? BTW, it looks good.
    You don't have to cut the bumper. The lip wraps just around the middle bar section of the bumper. It fits very well with no modifications. You just need double sided tape and a little drilling to mount it. I'm going to have to remove it again or tape of sections of the bumper so I can paint it white.
    The ebay seller I got it from still has a lot in stock. Check out the link in my first post.
    10R New Member
    From the front and the side, the ridges that remain where you cut out the piece of bumper running across the middle of the air vent should be sanded down. Otherwise it doesn't look right.
    I've tried... but that's the best its ever going to be. Its a protruding ridge so even if I did sand it down more, a hole would form in the front. I've covered most of the hole with bondo already so it looks 10 times better.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    the lip looks good, but why was your bumper cut in the first place?
    SC
    paint the ridge black, i think it might blend in better
    SaberJ2X Lurk MOAR
    Mayawest, PR
    shave and bondo it into the body
    god knows I shouldn't have photoshop'ed today....
    clearly not my best work... but meh for 3 minutes
    Rincon , Puerto Rico
    Nice lip on the car but you need some more light ....lol.... other then that it looks tight .... do you have side ones ???
    No. I have the stock S skirts.
    dward3 Well-Known Member
    Phoenix
    If you paint it primer white you can leave your side skirts as is. your Corolla looks pretty clean :D
    hehe thanks. I'm actually going to paint it white with some color matched car spray paint and then a few coats of clear.
    I painted it. I posted pics in the 8th gen showoff megathread.
    rayray1 Active Member
    stolen pics ftl
    I gave him permission to use those pictures. hehe
    Black or White?
    I'm thinking about painting my front lip black again. Should I do it? It gives it a more aggressive look. I'm not going to consider painting the skirts or rear valences, only the front.
    Remember that I have black headlights and corners now.
    Joeyicu New Member
    keep it white, looks clean, the black makes it look unfinished
    so cuting those pieces out of the front bumper, was there anything speacail involved in doing the work?
    and im so geting one, they are cheap to :hit3
    I didn't need to cut those pieces out at all. I had in fact already removed them as a previous modification. It will fit without any cutting. You will have to drill. That is about it. Everything else requires 3M tape.
    Joeyicu New Member
    im fully aware, im actually pretty good at this car stuff, i do it for a living, and i am fully certified
    i was asking becuse i think i may do it, because it hardens the look of the car up alot, makes it look agressive and less cutesy, i think on mine tho i would op to inset some sort of girll where the holes are, but yours still looks excelent
