Engine got a question - for those who REALLY know their engines
Discussion in 'Powertrain' started by falnfenix, Jun 2, 2005.
    a buddy of mine out in Cali aquired his aunt's Prizm.
    it's a 1990, and it's EXACTLY the way it rolled off the assembly line. we know it's special ordered, since his uncle worked for GM at the time. it has full GTS suspension stiffening, and a not-quite-stock motor.
    can anyone tell us what that motor is?
    your help is appreciated :)
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    looks like a 4age smallport...sorta
    Denver Rolla 98 impreza
    is there not the engine tag on the side... should eather be on the passenger side... near the middle top of the block...
    JLee TD05 3SGTE
    NH
    Does it say anything on the timing belt cover?
    Corolla DX-R AE100
    Vancouver, B.C.
    looks like 4AGE...
    to those who said 4age - thanks for confirming, that's what i thought.
    he didn't say anything about what it said on the engine, just that it said TWIN CAM in orange lettering.
    AE102 New Member
    yep, i seen that type of engine before, it is a 4AGE. the one thats definately not from japan, i think.
    and omg, your sig :rolleyes:
    toyotaspeed90 New Member
    Bellingham, WA
    smallport 4age
    the car is a 90-92 prizm GSI...... the non rare non-map based version...... it has the same suspension as an ae92 GTS (including front/rear swaybars, rear disc brakes, serviceable struts, and the obvious upper strut brace). GSI's also came with the larger 14" wheels, a lip spoiler on the trunk, and a red-filled geo logo on the front grill
    it's a US motor.... has the EGR stuff.... (could be a japanese block, however).
    it's not special order or anything.... there were a lot of gsi's produced (i live in a small town and know of at least 3-4 of them driving around)
    Bellingham, WA
    i can go into more detail if you want..... :)
    7 rib block, 10.3:1 pistons.... the cams are smaller than the bigport 4age's (which is a common upgrade). Has factory oil squirters, 42mm rod journals, 212mm flywheel (if it's a stick.... most gsi's are, but there are some auto's out there).... wrist pins are larger on the 7 rib block 4age's over the 5 rib...... lack of t-vis..... um, i dunno what else to say
