Good drop on a 95 soon to have bodykit?
Discussion in 'Stop, Drop & Roll' started by killer2239, Jun 21, 2004.
    killer2239 Lift at 5700rpm
    Lexington, KY
    Ok, whats a good drop rate to get on the car when i do the suspension? I plan to get a full body kit around time that i do it. So what do you recommend the drop rate should be? I dont want to low, i do have some areas where it is a steep drop or incline. Most i can avoid, but you never know.
    d_samurai Guest
    well-when going with good lowering springs like eibach or trd, youd'e expect a 1 inch drop-which is usually the best way to go=for some its not low enough- but it looks perfect with 17 inch rims..
    RacingSolution New Member
    A good drop is about 1.3 - 1.8" ... once you add the kit, it'll look very aggressive... anything lower than that and you'll REALLY have to watch the dips in the road.
    Lexington, KY
    I have 15" :(. I will get 17" next year when i get more money, and sell mine for a 100-200.
