Engine Getting the TRD supercharger
Discussion in 'Powertrain' started by 1.8greyghost, Jun 25, 2004.
    1.8greyghost Guest
    Well guys went to the dealership today and had a nice long chat with the Parts manager and disscussed modifacation and warentee issues. This is what I got, 2530 dollars for the 1zz-fe supercharger, and about 1000 dollars instalation. But I don't pay shiping and the engine will mantain the factory warentee. so after tax it added up to about 3800. So I think I am going to get it done this coming tax check. I know some of you have done this, what should I expect out of the car, and what are your opinions on Advantages, dissadvantages?
    burbod01 New Member
    i don't have a s/c so i don't know what the advantages are, but the price sure is a disadvantage
    blancokracker Guest
    Should be able to install the actual s/c yourself very easily I would think. But I bet the only way to keep warranty is to have them install it.
    capntoo New Member
    The paperwork that comes with TRD parts states that if the Dealership installs the TRD parts, the warranty remains original. If the owner installs the parts, they are covered for one year.
    Silver_Nitrate New Member
    I've heared, they will reduce your lag big time, better than turbo cuz they won't burn up your engine that fast. I thinks it gives 30 or more hp at the wheels. What year car is that going into?
    well, the s/c is better for reduced lag/low end torque - because there IS no lag, like you'd get from a turbo. it'll give 40 HP to the wheels at 6lbs of boost...more if you up the boost.
    RollaS New Member
    um you need to take the supercharger to a different dealership to get it installed. Everywhere i have gone has quoted me $390 for install. Nobody on the boards has paid more than $500 for install.
    unless they are modding it to fit his vehicle if its not 03-04.
    blancokracker Guest
    ....there would be no warranty for it then.
    even if the dealer put it in?
    since it's not meant for anything older than 03 i don't imagine the dealer would do it.
    corollarider19 New Member
    i would have the dealer install it but make them lower the price its a rip off
    CadetLee Guest
    Yeah..call around on the install -- you should be able to get a turbo installed for less than that, and a s/c is a whole lot less complicated. :p
    p1ccoloz Guest
    add an exhaust and dc header to that you should do decently well. and if you get the urge to spend more money add a pfc and tune it instead of the management trd gives
    1.8greyghost Guest
    Yeah that was a guess price for the install, he said it might be 500 or so. But besides that, the S/C would be going on my 04 S. I just want my rolla to be able to run with a Stock GSR, if not a little faster. Do you think it might be able to do that?
