Engine Gears grinding
Discussion in 'Powertrain' started by 93geoprizm, Sep 19, 2007.
    93geoprizm Active Member
    Gears grinding
    So i usually redline here and there to feel that torque and of course the intake. now when i shift into third, my gear grinds, this is only in third, the rest it just engage pretty smoothly. so what i do is, when i get out of second, i press the clutch, hold for the revss to drop down to 5K and then shift, then its ok, but if i do it best motoring style lol i hear thatloud clunk, what do you guys think it could be?
    you
    at this rate, you'll break your car man.. the car was never designed to drive like that
    jcrwzr Member
    Simi Valley, CA
    my second gear used to do that. i prayed and it went away the next day. no joke.
    or... maybe i'm not talking about the same thing as you are, but at one point of my corolla ownership, i felt a little gear grind going into second at 5000rpm.
    Silver Bullet New Member
    Your synchros are shot. I had the same problem and I never redline.
    i dont do it all the time, very seldom
