gauges..
Discussion in 'Interior' started by HK-Racer, Jun 29, 2004.
    HK-Racer Guest
    experience? what experience? you learn by making mistakes man.
    infamousrolla Guest
    gauges..
    im installing some reverse glow gauges... i need help on where to put the power wire... this is so confusing... if anyone has pics it'd be good help to...
    thanks in advance.
    Silver_Nitrate New Member
    power wire can be tap into anything that has 12 volts. preferably your headlight switch. use a 12v meter to see if you get a constant power on one of the wire, that will be your power. then turn it on and off and see which wire loses the 12 v, that would be your switch
    SkyAce2004 New Member
    is it just me, or is there alot of talk about indiglows again?
    CraigW New Member
    Constant 12V available at clock connections. CW
    d_samurai Guest
    b/c of all these horror stories of failure and mess ups, im totally avoiding glo-guages-why go through all the suffering? especially if the individual doenst have prior experience
    HaPpYfAcE New Member
    Tucson, AZ
    use the fuse, dammit! left kick panel on the driver's side....look at the back of the cover for which one is for the parking/headlights and just take it out...wrap the wire around one of the teeth and stuff that biatch back in there.
    :D
    CaptainCorolla Thread Captain
    Orange County
    infamous:
    What year is your car? Use your car body or a bolt for a negative connection, tap into your current gauges for positive. If you have 98-02 I can tell you which wire. Ok, I'll tell you anyway, it's the brown one going into your gauges, good luck! Test with a test light first, in case I forgot the color.
    theproof Guest
    so these things dont fully replace your gauges they just go over it?
    Tucson, AZ
    that's correct....unless you change the backlighting in the cluster, it still has that shitty yellowish glow....bleh...doesn't look good with the reverse gauges, but when i had mine, i just turned it down enough so i could still see the odometer and temperature controls and that was good nuff.
