Gas brand comparison
Discussion in 'General Discussion' started by bigdaddyk, Jun 17, 2004.
    bigdaddyk Guest
    I've been using Amoco 89 for the last six months and averaged about 28mpg over this six month period (around 50% highway / 50% city). I was thinking about switching over to Sunoco to see if I could do better. Has anyobdy run Sunoco for a while with any better results?
    bigdaddyk Guest
    Nobody uses Sunoco???
    EmAn z 31 Guest
    Only Exxon/Mobil for me.
    whosgottheherbin Guest
    i use all kinds of gas ive found that as long as you find gas that your car likes no matter the cost keep using it
    RexPelagi VDub
    Canton, Ohio.
    I use citgo, but i heard sheetz is really bad gas, if you have one near you guys.
    Dimsum New Member
    Cheveron or Shell 87 if im poor, 91 if im feeling rich
    w1ngzer0 Guest
    all the same just different additives
    1ZZ-ROLLA-S Guest
    Well, with the 2ZZ, I have to use premium........Shell 93 everytime.
    nikeair11 Guest
    I use Chevron 87, or 76 if there's not a Chevron around. MPG is usually around 30-31.
    Schoat333 New Member
    i use sonoco usually and i get 37-38 miles per gallon 50%city and 50%highway and i dont drive it easy.. i use 92 octane too.
    RexPelagi VDub
    Canton, Ohio.
    damn you people with good gas mileage :evil: :evil: :evil: Im going to check mine again at next fill up, i wonder if im above 22.
    my cars a 5spd also so im gonna get better gas milege than you auto people
    RalphWRules Guest
    I get 31 mpg on regular gas, no matter the brand. I have an auto too.
    tom Guest
    I use Chevron w/ Techron 91 octane always. I don't care if I have to pay $2.60 a gallon compared to the cheap Arco 91 gas.
    zhentipede Guest
    by experience i use any gas.... except arco... something to do with the additives.....
    i prefer chevron thou
    is it true that BP gas kills your fuel system?
    bigdaddyk Guest
    I hope BP isn't bad for your fuel system, because that's all I've been using for the past six months (BP Amoco). From articles that I've read, Amoco is supposed to be one of the cleaner gases and lowest in sulfur. Where did you hear that BP is bad?
    RollaS New Member
    my dad was told by the dealership not to put BP in his BMW a few years ago because it would clog his injectors...........i pretty sure BP has changed their mixture since then.
    yea i was told by many people when i used to work at a car dealer in medina not to use BP cause it has adatives that clog injectors and fuel pumps.
