Engine Fuel injectors
Discussion in 'Powertrain' started by jtweezy, Aug 10, 2005.
    jtweezy New Member
    Irving, TX
    Fuel injectors
    hey I need some 550cc high impedence fuel injectors....and well does Ne body know if there are some from another toyota vehicle i could use that fit ?
    JLee TD05 3SGTE
    NH
    What engine?
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    prolly a 1zz im guessin...
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    You can use the ones off a Supra.
    I don't think those fit Vamp. I've taken a look at them and they just don't appear to work in the 98-99 heads. I think that's a rumor that no one has tested.
    Your best bet: Purchase a set from MWR (power enterprise 550cc)
    Rosedale, MD
    Ah, well thanks for dispelling that rumor then. Yeah, looks like MWR is your best bet for 550cc's.
    Sadly, I think it was Duwayne that first mentioned the Supra injector thing - a good chunk of the people just took off with that theory and ran with it. When I was looking for injectors last year I found that nothing but the skinny profile would fit, hence the PE injectors were the only ones I could find that would work.
    Rosedale, MD
    Duwayne started that? I originially heard it was Cressida turbo injectors that would work, and I saw the Supra was the same engine, so I figured, Supra injectors. Lol.
    yeah his famous quote ' yep, im runnin turbo, just use supra injectors '
    bah... what an idiot
    I hear DSM injectors fits toyota.
    some fit toyota, but not the small profile ports on the 1zz heads
    to my knowledge 450cc DSM would fit 4/7afe perfectly.
    Cape Coral, FLorida
    damnit, 2 bad i wasnt around when this duwayne character was, i wuda loved to see him gain his horrible rep
    Yes because your head will allow them in. Our injectors (98+ 1ZZ/2ZZ) are burrowed into the head pretty deep. The fat ass on 95% of the injectors won't clear it enough for you to get the tip down into the seal. You *HAVE* to use slim injectors.
    what size are out stockers on the 7afe?
    ^ You mean flow rate? Our injectors are weaksauce, off the top of my head they're 172cc.
    Vortex.. so would the ZZ injectors fit A series fuel rails? I would like to use the set from power enterprise myself.
    ooo i dunno... they may fit... i've got a set of both types of injectors in my garage, i'll take pics and compare and post in here tomorrow.
    cool! good stuff man.
    well if it dosn't work I guess i'll go the cheaper router and go with dsm 450's.
    BTW Toyota injectors are saturated not peak and hold correct?
    [edit]
    Also found FC3S injectors would work well (on 4/7a at least :D )
    88 | 13B NT | high | square | offset | 460cc | purple | 195500-1350
    88 | 13b T | high | square | offset | 550cc | purple | 195500-1370
    89-91 | 13B NT | high | oval | center | 460cc | red | 195500-2010
    89-91 | 13B T | high | oval | center | 550cc | purple | 195500-2020
    I believe our plugs are oval? so 89-91's would be a nice find and direct swap.
    Barnacules 100101101011011
    Duvall, WA
    What happens if you put 550cc injectors on a stock 1zz-fe non-boosted? Anything happen? Any gains or losses? I have a friend selling 550cc injectors and I would buy them if I had anything to gain.
    don't quote me on sayin this, but i believe so.
    You waste gas? hehe unless you have the need for extra fuel (ie more air to mix it with) then it does you no good.
    I'm pretty sure u need aftermarket fuel management anyways with 550 injectors
