Engine Fuel Atomizer 2000
Discussion in 'Powertrain' started by LowRolla, Jun 23, 2005.
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    interesting, but i definitely wouldn't pay over $100 for something that I don't know if it actually works. just cuz they SAY it works doesn't mean anything lol.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Fuel Atomizer 2000
    https://www.doubleyourmiles.com/index.html
    I found this by accident. It's an oil catch can (between the PCV valve and intake) that adds atomized fuel to the manifold (which should easier) while removing blowby oil and sludge from the intake.
    kickarse Guest
    Saturn owners frequently do this to help in the problems they have with the engine eating oil like a fat kid and cake..
    Neways you can build it for a LOT cheaper
    whitekorolla02 Guest
    here's wat my brother had to say about this when i asked him if it works... i kno, i kno .. sorry it's in spanish.. can someone translate it???.. i'm at work and i have to go now.
    Nah!!, es solo un PCV valve modificado. Ahi dice que todos los injectores manda cierta cantidad de gas liquido, Eso es mentira. el trabajo de un injector es lo contrario, atomizar. Los unicos injectores que tiran gasolina en liquido en vez de atomizada son los carros GM, y eso es porque siempre han hecho un mal diseño con los injectores (son de plastico) y se dañan rapido . Cuando esos injectores se dañan ( que empiezan a " botar gasolina la gasolina en liquido" se cambian por los Bosch type injectors y se corrije el problema. Fuckin Domestics.
    a menos que tengas un GM no se lo pongas, gastadera de real. Garbage.
    De los 11 carros que probaron. 8 de ellos son domestics, y son mas viejos que la sarna. con un cualquier cosa que le hagas a un carro del 83 claro que le va a cambiar el MPG.
    scrotarolla Guest
    Tu hermano, I mean your brother is correct - it's a scam. Get the TORNADO instead.
    91DX Guest
    you are being sarcastic right?
    asn13oy Stepping Stones
    OC, CA
    5 years of spanish in high school and 4 years later I forgot 95% of what I learned.
    However I think the main point of what your brother's saying is that this would mainly be beneficial for older model GM cars that have poorly designed fuel injectors (made of plastic). Those would deteriorate quickly over time, and thus shoot out fuel w/o atomizing it (turning it into a mist). Did he say that they've corrected the problem by switching over to Bosch injectors?
    Of the eleven cars they tested eight of them were domestic, most of them were old, and......."Fuckin Domestics"
    felixrolla Guest
    Translation: <br />
    <br />
    Nah, it's just a modified PCV valve. They say that all of the injectors send a certain quantity of liquid gasoline-- that's a lie. The work of the the injector is the opposite... *to atomize*. The only injectors that squirt liquid gas instead of atomize are GM cars, and this is because they have alwyas had a bad fuel injector design (they're made of plastic) and they break quickly. When those injectors break (when they start to leak liquid gasoline), they put in Bosch injectors and this corrects the problem. Fucking domestics. <br />
    <br />
    Unless you have a GM, don't put in atomizer. Garbage!<br />
    <br />
    Of the 11 cars that they tested, 8 domestics, and they're old as hell. You can do anything with an 83 car and change it's mpg.
    scrotarolla Guest
    You might just see better results. The placebo effect, I believe that's what it's called. :)
    phillipguru Guest
    Could you use that as a pickup line, baby i'm gonna atomize your fuel like no other domestic could.
    Rosedale, MD
    OC, CA
    That wouldn't be saying much though.
