FRONT, STOCK sway bar diameter size for 98-02 Corollas?
Discussion in 'Stop, Drop & Roll' started by MY_ROLLA, 2005年10月18日.
    MY_ROLLA Guest
    I have the factory, front sway bar on my 98 Corolla. Apparently, the front sway bar bushings are making noise and the alignment shop recommended that I replace these when I get my next alignment done.
    Instead of getting factory bushings, I want to use Energy Suspension bushings. However, they apparently don't make a kit for the 98-02 Corollas, but ES sells bushings individually based on the diameter size of the sway bar.
    So, with that said, does anybody know (or can measure) the FRONT, STOCK sway bar diameter size for the 98-02 Corollas? Thanks.
    sxlostv1 New Member
    Los Angeles
    front 22mm, rear 14mm(??)
    Get superpro bushings.
    statik New Member
    Can't you measure it yourself?
