Front end noise
Discussion in 'Stop, Drop & Roll' started by easyrider, Sep 7, 2007.
    easyrider Guest
    Front end noise
    1999 Corolla,60,000 miles. My car makes a distinct thump sound when I drive on rough road surfaces at low speed.The mechanic said that he found that one of the two small stabilizer bar links(driver side) had play in it,everything else in the suspension system checks out fine.The machanic said that I probably hit a pothole and damage that part,Is this possible?Anyone knows how to repair this?
    its possible. i've had something similar once. Hit a rock and damaged one of my struts and I had to a thumping and vibrating noises..
    easyrider Guest
    Update.
    All 4 stabilizer bar links were worned out..lots of play in them causing the noise when going over bumps.They act like mini ball joints on this vehicule.This repair took around 10 minutes and now it rides like a brand new car.
    shubert_ae102 New Member
    de mountains :D
    if it continues , check your upper strut mounts.
    imported_v10 Guest
    my car does the same thing and i noticed when i move the calipers they move a little im replacing some parts in them to see if it stop the noise!
