front conversion help
Discussion in '8th Gen' started by evelio seijas, Jan 31, 2015.
    evelio seijas Member
    cape coral, FL
    2000 corolla
    ive been looking into gettin an 02 corolla front i know all i would need is the bumper and the headlights if anyone has done it any tips on the headlight wiring for high beams
    do what i did get a morimoto h4 harness, this way you can still use your high beams and low beams at the same time... and you dont have to cut into anything
    http://www.theretrofitsource.com/co...ntrol-bi-xenon-wire-harness.html#.VM1zIlXF-qI
    You need
    1x Bumper
    1X set of head lights
    2x bumper side support brackets
    (not mandatory)2x 01-02 fender liners
    and have fun
    cape coral, FL
    2000 corolla
    thanks for the help. can u post a link for the support brackets? i can't find them
    Thats a dealer part only
    1. 5211512370
    2. 5211612330
    cape coral, FL
    2000 corolla
    98 Corolla
    oh and please get an oem bumper from your local junk yard. the ebay 1s are not an exact fit..... ask me how I know -.-
    cape coral, FL
    2000 corolla
    fuck...i ordered the ebay one
    cape coral, FL
    2000 corolla
    shit i was thinking the 00 and 01-02 had the same socket for headlight... my local junkyard doesn't have any 01 or 02 corollas so i can't just go and cut the wires and I'm not sure how the marimoto harness would work
    cape coral, FL
    2000 corolla
    i was thinking..what if i get an hid kit for the 01-02 and wire it to the 00 wires
    Nope, unfortunately
    cape coral, FL
    2000 corolla
    alright so from the junkyard i need to cut the wires from the headlights, high beams and corner lights?
    Corner lights are the same (so no need)
    But the head lights are complicated to go between the single and dual-bulb system
    cape coral, FL
    2000 corolla
    what do i have to do in order to do it is there some sort of wiring diagram?
    Yeah I think so, I'll have to wait for the other guys to chime in
    cape coral, FL
    2000 corolla
    the only 02 corolla in the junkyard the front was so fucked up i couldn't get the wires cus the connectors where all fucked up...but right next to it was a 2003 i believe corolla so i took the high and low beam wires from that because i saw that they are hb4 and hb3 sockets so.. will it work?
    Picknwnnrs New Member
