Engine French guys here please ! or english
Discussion in 'Powertrain' started by xplicitcorolla99, Jun 20, 2007.
    las vegas
    deathfire Guest
    Jai un probleme avec ma corolla 98 1zz fe automatique parfois a 80 ou parfois a 110 quand je tente d'augmenter ma vitesse l'auto ne le prend pas elle ping ou buck
    tentative d'expliquation en anglais
    im dont speak english so try to understand .. my 98 rolla auto trany .. have some problem when i try to acellerate at- 100 or 80 km/h the car beging ton ping or something i find a other guys with a similar problem ------------------------------------------------------------------------------------->>>>>>
    Date: 9/19/2004
    Subject: 98 corolla misfire?
    My 98 corolla (5sp, 4cyl, 174k km) which I bought used last week misfires or sputters if I try to accelerate. Had oil change 2 days ago, this problem started yesterday. I was driving at 100 km/h and tried to accelerate, the check engine light began to flash. Once I stopped, the light went out after 1 minute. If I don't accelerate quickly, the car is fine. This seems to occur mainly at low rpms.
    xplicit, read the second half of his post. dude doesn't speak English but needs help. the car is a 98 and misfires.
    Giacomo, have you taken it to get the check engine light read? there should be a code stored in the computer that will tell you more about your problem. I have been having a similar issue with my Subaru Impreza, so I know this is a frustrating problem. things to try: clean your MAF sensor, change your spark plugs, check your oxygen sensors to make sure they're reading properly.
    deathfire Guest
    clean your MAF sensor , check your oxygen sensors how to ??
    deathfire Guest
    did you try anything i suggested?
    first: do you have a check engine light?
    deathfire Guest
    the check engine flash just 1 time in 4 month but the problem apear not everyday just sometime..
    ok, did you have someone read the code when it flashed? if it's a FLASHING check engine light that means that you could have a misfire bad enough to damage your catalytic converter. it could also mean your oxygen sensor is bad, causing unburned fuel to go through the exhaust.
