Frankfurt 2009: 2010 Lexus LS600h revealed in full detail
Discussion in 'Auto News' started by Autoblog, Sep 18, 2009.
    Autoblog Guest
    Filed under: Frankfurt Motor Show, Hybrid, Sedan, Lexus, Luxury
    2010 Lexus LS600h - Click above for high-res image gallery
    For 2010, Lexus is doing a mid-cycle refresh on its flagship LS lineup, including the hybrid drive LS600h. The system mainly carries over hardware, but some of the controls are enhanced with the latest updates featured on the new Prius, HS250h and RX400h. Among those are a new ECO mode that applies a filter to throttle inputs and air conditioning control. Small adjustments in the throttle position are ignored, allowing the powertrain to operate at a more constant rate, reducing fuel consumption. Similarly, the air conditioning uses the recirculate mode automatically and allows more variation in temperature.
    One of the complaints we had about the LS when we reviewed it last year was the minuscule trunk for a car of its size. Lexus has reconfigured the nickel metal hydride battery pack to reduce the package size, allowing the trunk volume to be increased by about 1.24 cubic feet. The front brakes have also been upgraded with larger rotors and six-piston Brembo calipers. On the outside, the LS gets a new front fascia with a grille similar to the HS250h.
    Gallery: 2010 Lexus LS600h
    [IMG][IMG][IMG][IMG][IMG]
    [Source: Lexus]
    Continue reading Frankfurt 2009: 2010 Lexus LS600h revealed in full detail
    Frankfurt 2009: 2010 Lexus LS600h revealed in full detail originally appeared on Autoblog on Fri, 18 Sep 2009 08:59:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    More...
