Engine For you engine swapping Corolla guys
Discussion in 'Powertrain' started by BLADDER_MASTER, Aug 30, 2004.
    BLADDER_MASTER Active Member
    FL
    The V6 weighs as much as the 3S-GTE and it's a given that the 3S-GTE is heavier than the 1ZZ-FE (Iron > Aluminum in weight). So indeed I bet there was a weight difference. How much I don't know.
    Clon3 Guest
    it would suck to finally accomplish the swap successfully then find out the passenger side of the car is lowered 2" more than the driver side =\
    FL
    http://spyderchat.com/phpBB/viewtopic.php?t=14132
    CadetLee Guest
    Heh..after I finish school (or get paid enough that I can afford a second car), maybe I'll keep mine in a garage and mess around with an Avalon engine..
    It would be awesome to run a V6 and dual exhaust on a Corolla, and have it sound halfway decent..getting it to look right is another problem altogether. :p
    Just think -- you can tell people you have "headers" in your Corolla -- and they can't correct you! :D
    Corolla DX-R AE100
    Vancouver, B.C.
    i'm just wondering if that engine screw up the weight distribution...
    killer2239 Lift at 5700rpm
    Lexington, KY
    I dont think it would be to much difference for it, at least lets hope so :)
    rollaracer4 Guest
    that was way too much reading...j/k im with cadetlee all the way
    CadetLee Guest
    Lose weight and relocate your battery. Problem solved. :p
    02RSX Guest
    ummmm...the engine is already in the rear. u need to gain weight, and add a couple more batteries :p
    CadetLee Guest
    I was referring for a swap into a Corolla -- however, Corolla DX-R wasn't clear as to which car he referred to..
    Ah well. =)
    CadetLee Guest
    http://www.spydermods.com/Greenie/1MZ-start.MPG <-- rightclick -> Save as!
    toyotaspeed90 New Member
    Bellingham, WA
    i know it's one of Bills cars...... i'm an mr2 owner as well, so i'm on that board more often than this one....
    Bellingham, WA
    that's nothing... you should see the mk1 mr2 that's getting the 32v northstar V8... and he's twinturbo'ing it
    FL
    That's Bill Strong's MR2 from MR2OC.com. You should also see the Twin-Turbo 1UZ-FE V8 Celica.
    FL
    Oh ok. Cool. I check out the MR2 board often as well to see what's the latest 5S-FE mods.
    Bellingham, WA
    yeah... i'm not too much of a mk2 or mk3 mr2 fan....... mainly because i enjoy a cheaper car to work on.... i'm in the middle of an S/C swap and cash out of my pocket i'm only out about $500 including buying the rust free car, the megasquirt ecu setup, and the JDM 4agze with LSD tranny (it cost more than $500, but it's hard to explain... i bought another mr2 for $200 then sold it for $700.... basically only $200 of that was mine.... used the $700 to buy the motor/tranny)
    FL
    Damn, sounds like you got a lot of work ahead of you.
