Fog light bulb swap...
Discussion in 'Exterior' started by polo708, Mar 27, 2004.
    polo708 New Member
    9thgencorolla.com
    Is there an easier way to change the bulbs in my fog lights, other than laying under the car and trying to change them "blind". I have a rolla S.
    TheBeak Guest
    yes. the fog lights are held in place by a nut on a stud. remove the nut, swing the light out and away, disconect the harness and bulb swap to your hearts content.
    be careful though, on each light, one nut holds the light in, and there is another nut like object used to adjust the aim piont on the light. look twice, loosen once :)
    by the way, love the E34. i had a deal going last year for a '95 540 6 speed, (we were at $13.5k out the door) but the deal fell through when i found out it still had the nikasil block. (it was out of factory extended warenty) he wouldnt garentee the block, or drop the price, so i walked away.
    still hoping to run across a low miles 95 540 m-sport :)
    polo708 New Member
    9thgencorolla.com
    Thats sounds easier, I was trying to do it from underneath... just feeling around, but had no success. Thanks man.
    sleekaman Guest
    Hears a good question
    I've done the fog light bulb switch many times, and see that little cogged screw for the aiming. What is the correct direction to raise the aiming of the bulbs, can't really tell the difference when I turn it, its very slow and slight, can't tell the difference, clock wise aims up or down, any comments or experiences are greatly appreciated...
    thanxs,
