Flush Mount LCD kit
Discussion in 'Interior' started by iceb8, May 14, 2004.
    iceb8 Guest
    Flush Mount LCD kit
    Has anyone seen the LCD flush mount kit for an 03-04 corolla. It looks as if it replaces the dash insert for the radio around the air vents. Anyone know where I can find it? Thanx.
    iceb8 Guest
    brownbanana ToadMotorSports
    Oahu, Hawaii
    im not sure i know which kit youre talking about. do you have any pics of this?
    Rainmaker Guest
    what size screen can be flushed mounted in the stock headunit area on the 03/04? :confused:
    Myamaguchi1 Guest
    ive seen one before someone on the old vvti did it?? looks good looks like stock real clean
    corolla_man_j Guest
    that was a custom work though
    Mike4831 C-Town Pimp
    Statesboro, GA
    ya if it is the one i remember seeing it is good custom work.
    neonaiad Guest
    that whole car is tight, his back lights actually look good and that screen is nice
    Statesboro, GA
    Ya, that is the one I have seen before. That is hella good work.
    e_andree E
    MD
    Looks like its all still a work in progess.....
    PsyVash Guest
    But why would you have a flush mounted LCD screen and not habve fiberglass work done to the system in the trunk. The car is tight. My only suggestion would be to get rid of the box in the trunk
    SSJ_Rolla Guest
    iceb8 Guest
    if you used the stock dash piece would you fill in the empty spots with bondo? any ideas on how to get a matching color after all is sanded?
    That's really nice. I don't think I'm going to put a screen in my car, but if I did, that's the way I would want it done.
    Oahu, Hawaii
    he said he it wasnt a DIY, he paid a shop a couple hundred for the custsom mounted LCD and the relocation of the deck.
    Rainmaker Guest
    bondo should work... standard black paint should match no?
