Fiber Glass vs. ABS Plastic
Discussion in 'Exterior' started by Tenchi, May 5, 2004.
    Tenchi New Member
    I want to buy an Altis type Grill and there is 2 types, the fiber glass one and the abs plastic one. Which is better, as in, better fit, will not crack, fade...ect. Please let me know. Thank you!
    ctsire13 Guest
    ABS would be better
    SSJ_Rolla Guest
    Im not sure if there are 2 types but if so, then get the abs plastic it will not crack
    Tenchi New Member
    great, thanks for the info!
    RollaS New Member
    The grill only comes in ABS.
    However don't ever buy a body kit/lip that is ABS plastic (or fiberglass for that matter).....much crappier than fiberglass. it's thin and will be destroyed if you hit anything.
    Dimsum New Member
    Basically your saying go Poly Urathane?
    RollaS New Member
    always, when possible
    ph0bi4 Guest
    i thought abs was good because it bends instead of cracks
    RollaS New Member
    haha, if you saw my altis front lip, you'd think otherwise.
    Tenchi New Member
    ok so basically:
    Poly Urathane >>>>>>> ABS > Fiberglass?
    I guess they don't make a Poly Urathane grill? If they do, where can I get one?
    TheBeak Guest
    theres an ebay vendor that sells a fiberglass version, he claims superior fit to the ABS version the competition sells.
    then of course theres this gem ive been eying: CF ALTIS GRILL seems to me if you liked the CF look, this would be the way to go. it costs more for the part, but ther would be no painting costs so it would even out the price some. (OK its still expensive, but its CF.... )
    ph0bi4 Guest
    that thing has hooolala's name written all over it
