Engine Exhaust Pipe Size?
Discussion in 'Powertrain' started by Concordmk1, Jun 8, 2004.
    Concordmk1 Guest
    Oh my god! Please reduce the pic size. Killing my 56k here.
    burbod01 New Member
    i'm confused as to the purpose of that pic?
    Lekz Guest
    that pic is as big as CivicEater's wheel gap...reduce plz
    SkyAce2004 New Member
    ....uhm..hey bud. thats one large ass sig u got goin on there...mind reducing the size and puting up a pic where the car is clean and not in the process?
    Prizmatic Guest
    Exhaust Pipe Size?
    Does anyone know the stock exhaust pipe size for the 95 corolla/prizm?
    HaPpYfAcE New Member
    Tucson, AZ
    i'm pretty sure that it's 1 7/8"....
    d_samurai Guest
    haha-leave the poor guy alone-im sure he just made a mistako, well-your stock piping is about 1.75 inches-very restrictive, you want about 2.25-.5 inch tubing...ive currently got 2.5 inch. you should hold the hose infront of your pants-so it looks like your pissin on the car! that would be a great sig!
    Prizmatic Guest
    you have to take advantage of a digital camera when possible, so my brother took the picture.
    rolla02 Corollalcholic
    Delaware
    at least now its small,
    Prizmatic Guest
    HAAAAALELUYAAAAA!!!!!! I fixed the picture!
    d_samurai Guest
    take one of you pissing on the car! a true kodak moment
    Mike4831 C-Town Pimp
    Statesboro, GA
    I think its 1 7/8's...
    CadetLee Guest
    1 7/8" -- I went with 2.25..much better.
    COROLLA1ZZ New Member
    Im running a new 2.5 catback and a trd muffler
    it's 2" OD but it's crush bent
    corolla_racer Guest
    its 1.75in....man the picture is killing my....
    Prizmatic Guest
    I am going to put two flowmasters on my car with new piping, probably 2-1/4".
    Lekz Guest
    one is just fine
    Prizmatic Guest
    But i like the look of two
    Prizmatic Guest
    yeah, i know that the exhaust gases will cool off and move slower through the pipe, but its not like I have that much horsepower anyways, it would be for sound and looks, you know what I mean
    d_samurai Guest
    you mean your gonna split your exhaust into 2 outgoing pipes? if so, you would take a big performance hit-exhaust temps will drop and lose velocity-gases will take longer to leave the car b/c they have to travel in different directions.
    corolla_racer Guest
    and if u do that i might lose hp to man...so its up the up and more wight to...
    corolla_racer Guest
    u might lose hp...i mean
    Prizmatic Guest
    That doesnt make sense, your car doesnt run better with back pressure, if the gasses in the exhaust pipe cool then that will reduce power but there is not such thing as back pressure producing horsepower. I understand that if I have two mufflers then I may loose a little power, but I think for me it would be worth the small power lost just to have a nice sound and look to my car. why do you think the dual exhaust wont sound good?
    You will loose to much back pressure for the engine and it will run like trash and it is not good for your car...........its a rolla not a honda v6 or a stang. just go to 2.5 pipe and it will work beter for your engine.... Y ad the extra weight to your car?
    corolla_racer Guest
    if u are going with sound with dual its likly to sound bad...
    Tucson, AZ
    with less backpressure, you will lose torque, which you prolly have very little of anyway. you'll have a really low idle, too, or it'll just feel really weird when it idles...might shake a lot. you should notice something of a gain in the top end, tho...but your off the line starts will suck azz.
    d_samurai Guest
    with no backpressure-you lose tons of low end torque-so basically-you tap the pedal-and you wont feel that new car "pull" or sensitivity...in my car-i have to push the pedal to the floor to bring my rpm's up to make any kind of decent power b/c of my 2.5 inch exhaust system...
    Prizmatic Guest
    I love the sound my flowmaster has, thats why I think two would be bad ass. I took the resonator off and it sounds nice, I can imagine two flowmasters reverberating with each other, hell yeah I can hardly wait. Plus I think that dual mufflers on the back just makes the car look more aggresive.
    Prizmatic Guest
    I will probably keep the stock exhaust size and have dual exhaust, that should help the exhaust flow enough without cooling the exhuast gasses too much.
